Gs pallas
Thread: Gs pallas
    Fellow Frogger! lamoor's Avatar
    sydney-newport
    376
    Default Gs pallas
    Hi all would like to know the best way to clean and restore the aluminium hydraulic pipes. Started to re assemble the car back to get it on the road.
    Any helpful hints or cleaning tips would be appreciated.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,166
    For a start the pipes are not aluminium. They are a composite metal, mostly steel and have a protective coating on them ( the metalurgical gurus will tell you the exact composition). If you polish through this coat by aggressive buffing they will rust. If they are in good order just wash them with a solvent and wipe them with a rag until the built up muck comes off. If they show areas of abrasion or rust replace them.
    Cheers Gerry
    sydney-newport
    376
    Default Gs pallas
    thanks for the reply and advice. will use a mild solvent, i would like to replace however, these pipes are not easy to get or get of find NOS stock is not an option any more.
    will do the best to achieve a as new result.
    thanks again.
    3,166
    Plieades.
    www.manta.com/ic/mxxh2nj/au/pleiades-automotive-hydraulics-australia-pty-ltd
    Cheers Gerry
    tweed heads
    1,544
    Default brake lines
    i took min to the local brake place ,and they made me some up ,cheep PUGS
    3,166
    It is a special tool to form the union flare for the pipe seal. It is not just an ordinary double flare as found on most cars brake lines.
    Cheers Gerry
