Try this on your C5 and let me know the results
Results 1 to 22 of 22
    Aug 2005
    Merimbula, NSW, Australia
    323
    Default Try this on your C5 and let me know the results
    1) Start the engine.
    2) Push hard on the brake pedal and hold the pressure for 15 - 20 seconds.
    Does your pedal slowly sink to the floor?
    Does it eventually reach the floor?
    I had my brakes bled by a Citroen dealer (including the ABS), but the pedal will still sink to the floor (eventually).
    The dealer assured me that all C5's exhibit this behavior. I'm not convinced, so please help to prove them right.
    I am thinking the master cylinder seals must be allowing the fluid to leak back.
    Thanks.
    Leon
    1987 Peugeot 505 GTD
    2010 Citroen C5 3.0 V6 HDi
    Mar 2013
    86
    Mmm. ABS brakes have a very different feel to older power assisted brakes for example. First time I drove one I thought the brakes were faulty.
    10,188
    I think that is actually normal behaviour for the C5 and will eventually happen if you stand on the brake pedal for some time. I can't see why the dealer would tell you it's normal if it isn't normal in their experience. Do they stop the car correctly?
    Aug 2005
    323
    Default Re: Try this on your C5 and let me know the results
    Yes, the brakes stop the car quite well.
    Leon
    Aug 2005
    323
    Nobody game enough to try this?
    Leon
    Feb 2011
    brisbane Au
    940
    Icon11
    Quote Originally Posted by dieselman View Post
    Thanks.
    It's caused by the ABS, and is perfectly normal for a C5 [as David S says]. Replace the brake M/C if you will but it won't cure anything.
    Aug 2005
    323
    I think I'll leave it well alone.
    The brakes are quite good now after the dealer bled them.
    Leon
    Banned Haakon's Avatar
    May 2002
    canberra...
    8,876
    Holy crap - who is this dealer and why are they not on ACA for dangerous advice!!??
    The C5 (as far as I know, please correct me otherwise) has conventional brakes. This is a standard classic sigh of a failing master cylinder and it should be replaced immediately. As in now, without delay!
    Flipping 'eck... Do they not want the job or something?
    My ABS owning experience is a 406, a Xsara2 (C5 running gear in a 306 chassis), a Laguna and a Megane (and a Magna with German Bosch ABS) - none have done this.
    ABS is an "in line" system - it does not and cannot allow pressure to bleed off.
    Feb 2011
    brisbane Au
    940
    That's incorrect, but anyway it's just lost its residual is all, perfectly normal and it will probably improve over time once the valves find their seating. A new brake M/C will fix nothing.
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,448
    Quote Originally Posted by shanadoo View Post
    +1
    I agree 100%
    Apart from which, if you had your foot on the brake, pressed hard to the floor for 15-20 seconds without releasing and hadn't stopped, what speed were you doing when the brakes were first applied and why did it take so long to stop. Even if you were on an oil slick, in an ABS equipped car, the brakes would've released and applied any number of times.
    Fellow Frogger! flipperman's Avatar
    Oct 2012
    Melbourne, Victoria, Australia.
    417
    My V6 Triton does this from new. After 5 1/2 years of hard use it never fails to pull me up.
    CitroŽn's that own me
    - 2008 C5 X7 Tourer (Estate) 2.7 DoubleTurbo Diesel UHZJ - V6.
    CitroŽn's that formally owned me
    - 1990 BX TRI Estate Manual. .. . "Phoenix" - "Donated to Science"
    - 1990 BX TRI Estate Auto. (Traded In)
    - 1987 BX TRI Hatch.
    Australian Citroen BX - All about the Citroen BX in Oz
    May 2002
    canberra...
    8,876
    Where does the pressure go? Never ever seen it on the hundred or so ABS cars I've driven - whats so unique about the C5?
    Aug 2005
    323
    That's what I'd like to know too.
    Not many C5 owners wanting to try it on their own cars either.
    Strange that it only loses pressure when there is boost (motor running).
    Leon
    Oct 2012
    417
    Maybe it's just pushing down more due to a constant force being applied, then when you let go of the pedal it returns back to normal?
    Jun 2003
    Lauderdale, Tasmania
    2,888
    Mine developed a longer pedal travel and with the engine running and the car stationary you could slowly depress the pedal almost to the floor. The mechanic suggested a change of master cylinder which seemed logical and so I bought one for him to fit. There were two versions and the one with the stability control like mine was nearly three times the price (both versions coped with ABS). I wasn't able to drive it much after he changed the master cylinder as he stuffed up the suspension but the brakes were just the same. I could slowly push the pedal down against resistance to the floor.
    1000+ Posts bigkev414's Avatar
    Mar 2011
    gold coast queensland
    4,511
    I had one and while I didn't actually do what you said I noticed that waiting at the lights for instance the pedal would slowly sink almost to the floor. Always felt 'spongy' compared to other cars I've had. Bought a Peugeot 3008 and it felt similar. Stopped ok, but did feel 'soft' and gave me that 'sinking feeling'.
    I might act like an idiot, and I might look like an idiot, but don't let that fool you: I really AM an idiot!
    May 2002
    canberra...
    8,876
    I still don't buy it... Until someone can tell me why this is so, all I can think is pressure loss/bypass.
    Oct 2012
    417
    A HSV mechanic friend of mine informed me of this info. This anomaly happens only in a duel brake master cylinder which incorporates two pistons jointed together by a spring and a retainer pin. While sealed at each end the spring and retainer pin area has air in it, when you push on the pedal you push on the spring and the spring pushes the 2nd piston but by doing so it compress the air a little, by continuing pressing harder and harder the air is compressing more, moving the first piston further along thus allowing pedal movement, by releasing this pressure the spring and the compressed air return to normal. This occurs in new and rebuilt duel brake master cylinders. You are able to improve this issue by performing what is known as bench bleeding the cylinder. Otherwise it's normal action.
    Please: don't confuse this action with a pedal that fails to return quickly to hard again. Get your brakes checked if your pedal does not return quickly or your brakes lack solid pressure.
    Armidale
    2,582
    Have just purchased a D9 406 SV, which also exhibits this behaviour. If it wasn't for this thread I would have assumed that there was a problem, as the sinking of the pedal is quite noticeable. Does anyone know if an 09/2000 build 406 has a dual master cylinder?
    Flipperman, your explanation makes sense - air somewhere in the system would certainly allow pedal movement. From the name, I assume that a "bench bleed" is done with the M/C out of the car (thus allowing more air to enter the system )?
    Alec
    bas
    bas is offline
    Dec 2010
    50
    I tried it on my C5 yesterday and my pedal slowly sinks but never goes all the way to the floor. Does that help?
    Life is what happens to you while you're busy making other plans.
    Feb 2011
    brisbane Au
    940
    Quote Originally Posted by bas View Post
    C5 has single cylinder M/C. Pedal creep is normal, normal, normal. On all systems the ABS only works with motor running [the ABS ECU requires 13.7v min to operate from memory, but I could be wrong it may be higher] against a general system voltage of 12.2 max with motor off. Some pedals don't go right to floor as M/c usually runs out of stroke/travel.
    HSV guy has got hold of some pretty good smoko evidently. Half his luck.
    Feb 2011
    brisbane Au
    940
    Sorry about the "HSV guy" crack, it is not intended to be derogatory. Just a weak attempt at workshop humor.
