How much?
Results 1 to 10 of 10
Thread: How much?
    Nov 2012
    Perth
    34
    Default How much?
    Hey everyone.
    Not sure if anyone will be able to help, but thought I'd put it out there anyway.
    My c3 pluriel has had a look over by the mechanics and am awaiting prices from them once they figure out where they are sourced.
    Anyone had these repairs done before?
    Timing belt change.
    Helicoil put in sump plug
    Brake pads/rotors
    Window regulator/actuator
    If so, rough ideas on prices?
    Any help would be amazing.
    Thanks guys!
    Fellow Frogger! Trading Estate's Avatar
    588
    Timing belt change. say 1100 -1200 inc water pump
    Helicoil put in sump plug- not much 50?
    Brake pads/rotors - could be 1200
    Window regulator/actuator - could be say 120 labour 350 part ?
    '04 Megane
    Gone but not forgotten
    '71 16 TS, '72 16 TL, '74 15TS,'82 20TS Series 2, '85 25 GTX. '49 L15,
    Nov 2012
    Perth
    34
    Default How much?
    Ok. Add a service onto that and I'm looking at 3k+.
    I'm assuming those prices are worst case?
    10,192
    Quote Originally Posted by Trading Estate View Post
    Definitely replace the water pump and make sure to fish out any bits of the impeller if it's broken up. Also the tensioner/roller.
    Depending which one, where it's obtained from and who is doing the work, a new Pluriel window reg could be anywhere from $1-3K fitted. You have to strip a fair amount out to replace a rear one and the part could exceed $2K retail. Front regulators form part of the glass guide, so you can't easily leave them out. It may be worth looking for the repair kits that were on offer via eBay to fix them. If the front regulators are not correctly adjusted, the car will probably leak.
    Nov 2012
    Perth
    34
    Default How much?
    It's just the front passenger side not the rear. The mechanic seemed to think that was quite an easy fix?
    10,192
    Has your mechanic changed a Pluriel window regulator before? No, it's not a rocket science repair, but it does incorporate part of the glass guide, so it's not like most cars where you can remove the regulator and simply push the glass up while it's out. Hopefully, he can repair it for you? The clip that runs up and down the track is the same as a later Xantia from memory and they are left and right handed.
    Nov 2012
    Perth
    34
    Default How much?
    Hi David. Turns out he was thinking of the standard C3. All good. That can be on the back burner for a couple of weeks.
    Does anyone know the change intervals of the timing belt? 100k?
    Mar 2011
    Linton.Victoria.
    1,282
    Prices on brakes 'over the moon' -Should be able to do heaps better than that-
    Jan 2005
    Melbourne NSW
    855
    Default How much?
    Those sumps strip out very easily. When I come across one I retap the sump and fit an oversized sump plug
    Current stash
    too many.
    Passed over stash
    lots.
    Fellow Frogger! BallinaOB's Avatar
    Bathurst, Australia
    135
    I recently had a couple of similar jobs done on my C2, similar motor and doors, at a Citroen dealer in Sydney.
    Timing belt and water pump change (I supplied the water pump which I bought a year or so from a parts importer):
    Motor Kit $350
    Coolant $27
    Labour $340
    Dealer Total: $717
    I also had the door locking actuator and handle replaced ( local auto electrician broke handle mechanism when trying to replace actuator before I took it to the dealer to get the job done correctly).
    I bought a second hand actuator from wrecker $50
    Handle Holder RHF $103
    Labour $169
    Dealer total $272
    ( I know you are looking at replacing a window actuator but this may give you an idea of labour costs as the replacement jobs would be similar.)
    Anthony O'Brien
    2019 C4 Cactus
    2008 C5
    2007 C4
    2004 C5 Estate
    Previous
    2003 C5
    2004 C2 (now with youngest son)
    2006 C2 (now with eldest son)
