Traction brake light switch
    Nov 2005
    Wodonga
    109
    Default Traction brake light switch
    OK, my traction has no brake lights, been trying to find the brake light switch, where the hell is it!?
    1963 Morris Cooper 997
    1964 Sunbeam Tiger
    1969 Austin 1800
    1969 Lancia Fulvia Rallye 1,3S
    1969 Morris Cooper S
    Fellow Frogger! Trading Estate's Avatar
    587
    I think its down in the brake lines near the fuel tank.
    '04 Megane
    Gone but not forgotten
    '71 16 TS, '72 16 TL, '74 15TS,'82 20TS Series 2, '85 25 GTX. '49 L15,
    Fellow Frogger! tractionfan's Avatar
    280
    mines underneath at the rear of tghe left floor pan in front of the petrol tank. there is a bracket there.
    Brisbane Australia
    165
    My car is a Paris built car and the brake light switch is mechanical and actuated by a rod and spring and sits on the body down under the manifold, roughly below the carburettor, I don’t know about Slough built cars.
    Jun 2012
    north fitzroy, victoria
    191
    mine is a mechanical switch mounted on the firewall, drivers side, above the brake pedal under the steering column. there is a short spring attached to both the pedal and the switch; when the pedal is depressed the spring tugs on the plunger of the switch and the lights illuminate. you adjust the spring so they come on when it is lightly pressed... adjustment by twisting the sping to make it shorter or longer!
