Bleeding front brakes on a Citroen C5
Results 1 to 25 of 26
Thread: Bleeding front brakes on a Citroen C5
    Aug 2005
    Merimbula, NSW, Australia
    323
    Default Bleeding front brakes on a Citroen C5
    Hi All,
    I replaced the front disc pads on my 06 C5 yesterday.
    I had to remove the drivers side caliper altogether to support it whilst the piston was wound back in. I let some of the brake fluid drain out, as I intended to bleed some new fluid through anyway.
    I bled the brakes conventionally until no air was present.
    Now the pedal seems firm, but will sink to the floor when the engine is running and pressure is kept on the brake pedal.
    I read that a Lexia might be required to bleed the ABS system, so a trip to a dealer may be in order.
    Any suggestions are most welcome.
    Thanks.
    Leon
    1987 Peugeot 505 GTD
    2010 Citroen C5 3.0 V6 HDi
    Feb 2011
    brisbane Au
    940
    Quote Originally Posted by dieselman View Post
    Hi All,
    Thanks.
    Quite correct But i usually see the bank manager first Bloody rip off merchants.
    Oct 2005
    vic
    868
    Not familiar with this froggy marque, have you braked hard enough to activate ABS to see if this cures the problem??
    David
    Aug 2005
    323
    Default Re: Bleeding front brakes on a Citroen C5
    No, but I guess it's worth a try.
    Leon
    Aug 2005
    323
    That didn't work.
    I also pumped nearly a litre of brake fluid through.
    Not much better.
    Looks like the Lexia bleeding solution will have to be it.
    Leon
    CitroŽn Tragic UFO's Avatar
    9,810
    I believe there is a certain order that you need to do it in, starting at the rear. Let me see if I can find the info.
    Aug 2005
    323
    Is this the sequence you're referring to?
    http://autos.groups.yahoo.com/group/C5-L/message/10434
    Leon
    Feb 2011
    brisbane Au
    940
    That didn't work.
    Not much better.
    Again old buddy, quite correct. Lexia to operate the internal valves on the ABS is what's needed. No way out of it.
    Aug 2005
    323
    Booked in to get this done on Wednesday.
    Leon
    Jun 2003
    Lauderdale, Tasmania
    2,888
    Quote Originally Posted by shanadoo View Post
    exactly so!
    the time has arrived when you leave the bonnet tight shut, get any car serviced by the properly equipped dealer and when it gets too expensive you call the wrecking yard to collect it. How many people service their own refrigerators?
    11,302
    Quote Originally Posted by gerry freed View Post
    exactly so!
    So right. I wouldn't touch it myself.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Fellow Frogger! Ceenine's Avatar
    Devonport, Holiday Coast
    510
    Default C5 abs
    Load of rubbish, replaced pads, discs and brake fluid the other day - no problems.
    2014 C5 2.2 HDI Limited Edition Sedan
    2007 C5 2.2 HDI Hatchback
    2007 C4 1.6 HDI EGS Sedan
    Peugeot Mi16 Series 2
    Aug 2005
    323
    I think the problems start if you drain the brake fluid!
    Leon
    Newcastle
    2,800
    exactly so!
    Hi
    I agree that this statement is a load of rubbish. My refrigerator has gone for 20 + years without servicing, and still going strong. The lesson; "Do not buy Citroen fridges"
    I have replaced my brake pads without probems. Citroens problem is that they assumed some stupid service senarios, and the software is crap. So their service tools are the only ones that can make sense of it. However if we leave it to the dealers then we will just throw these C5 away, as the dealers in Australia cannot fix them anyway and as they get older the cost will be more than the cars are worth. Thats the point of AF forum.
    The old conservative owners from the "good old days"can leave it to the the dealers and waste their money, the others who wish to learn can share the knowlege and post on here.
    Cheers Jaahn
    Sep 2013
    Elphinstone Victoria
    537
    Hi Brainstrust.
    Help!
    A friend with a 2008 HDi C5 was on holiday in country Victoria when the low brake pad warning light activated. He was carrying spares for just this eventuality, he disabled the electric hand brake, set the car up for the work and extracted the worn pads.
    Then disaster strikes. A mobile phone call with a message takes his mind off the ball and results in the electric hand brake being actuated so now he has the pistons clamped to the discs.
    His question. If he cracks the bleed nipples and pushes back the calipers, inserts the pads and bleeds the system as you would in the 'good old days' is he doing the right thing. Where the car rests is not within easy access to any garage far less Citroen specialists.
    SF
    16,751
    Quote Originally Posted by ScotFrog View Post
    Hi Brainstrust.
    Help!
    SF
    Do quick search. David S has posted often on completely disconnecting the handbrake so this won't happen. It sounds like it does expensive damage
    shane L.
    Sep 2013
    537
    shane L.
    Thanks Shane,
    I checked out David S's comments.
    Sounds like he may have already entered the expensive damage phase unfortunately.
    Don't remind me!
    16,609
    Glass half full, or is he like my Grandma, viz: "Someone's stolen my drink!"?
    What's to lose from having a go - you may succeed, it may be damaged but usable in the short term, but to sit and bleat does nothing for fixing. If the calipers are on a helical drive, respect it when pushing back.
    16,751
    I'd be trying winding them back too first.... Worst case I'd get the pistons back in and the handbrake still doesn't work ............ Hey I own a CX ... the handbrake in them is usually barely any better than no handbrake
    10,192
    I think try to electrically disable and manually release the parking brake before going further.
    There should be a release pull in the centre console.
    ( This is from the handbooks page at Citroen Service. You don't need to logon for access.
    See: http://service.citroen.com/ddb/index.html )
    Then address the pistons and pads and hope the handbrake still works when applied later. It may turn out that the motor part needs to be dismantled to check for damage and backed off to get it to go back together.
    9,289
    There's an article describing how these devilish things work at http://www.motor.org.uk/documentlibr...1-techtalk.pdf. Citroen uses a cable puller type.
    They look like those made by KŁster in Germany.
    1,005
    I recently had this issue when i let the fluid drain below the master cylinder. Turns out there was air stuck in the master cylinder which needed removing. Once that was done bleeding proceeded as normal.
    Sep 2013
    537
    All good.
    In a separate thread somewhere my friend has responded and thanked the 'Brainstrust' for all the assistance he received. He has fixed the issue, car is mobile and prognosis looks good.
    Case closed.
    SF
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,081
    Oh dear, I think I will disconnect the battery before I replace the back brake pads on mine.
    Ken W
    9,810
    You don't need to disconnect the battery Ken, just follow logic.
    In the car's menu, disable the auto park brake
    With car chocked or hoisted, deactivate park brake (push lever down with ignition on)
    Turn off ignition - park brake should not re-engage
    The auto park brake will now not activate
    During the work on the rear calipers you can easily disconnect the ends of the cables from the calipers
