Rubber tubing
Thread: Rubber tubing
    Fellow Frogger! jlmdsims's Avatar
    Geelong Victoria
    136
    Default Rubber tubing
    Hello,
    Can anyone recommend a supplier so I can get my hands on some rubber tubing suitable for repiping the low pressure return lines on a BX. I have tried Google but got a bewildering assortment of responses, none of which seemed to fit the bill.
    Thanks again
    Jeff
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,166
    Try Ebay France, Type in 'Citroen Durite'
    Cheers Gerry
    Member Chimbu's Avatar
    Jun 2004
    Tweed Valley
    94
    Speaking of which.
    Has anyone been successful in logging on to eBay France (from Australia) to complete a purchase?
    10,188
    You'd only need small diameter hose able to deal with oil. The original is not reinforced, but if you are making up new piping with off-the-shelf joiners etc., then take the opportunity to use something reinforced. It doesn't need to be expensive, so measure up and see what you can find at Repco, Supercheap or Pirtek.
    3,166
    Quote Originally Posted by Chimbu View Post
    Speaking of which.
    You will have to register your user name and password with Ebay France before you can enter into a transaction. Be sure that the vendor will post world wide. In some cases I have communicated with a vendor and asked if he will post overseas. They are usually co-operative and in some cases quite surprised that any one in Australia collects/restores Citroen!
    Cheers Gerry
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,505
    I agree with Alan S. Measure the inside diameter of the tubing you need in both metric and imperial, as some is imported from the USA. It is known as "fuel hose" in the automotive shops and is suitable for oil. Supercheap usually have it on rolls in the shop for you to inspect and then get an assistant to cut to length. Repco hide it out in the back but usually bring it to the counter before cutting.
    I have used clear plastic tubing on a BX in an emergency. The main supply to the HP pump was clear plastic and the emergency ran for about a year. It looks nice and colourful with the light green flowing through it, becoming darker over time to remind you when it is time to clean the filters and replace the LHM.
    John
