Made a couple of D series tools.
Results 1 to 11 of 11
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,448
    Default Made a couple of D series tools.
    I like fabricating, tools especially.
    Needed a tool to check the position of the CRC (clutch re-engagement control) on a BVH equipped car.
    This is made from 2.4mm brazing wire, then silver soldered.
    The straight end is 25mm long, the circular end is for your finger, makes it easier to hold.
    Figured I'd probably remove the carburettor for a thorough clean too. How to remove the base nuts is a curly one, especially the one closest to the front of the car on the rocker cover side.
    Darrin Brownill of Citroen Classics suggested I probably had already made a special tool for removing the carby.
    Hmm, no I hadn't.
    Today I made a 1/4" drive 12mm crowsfoot from an old 1/4" drive socket (cut down for the drive section only) and open end wrench.
    If you own a 1970 or later DS, the open end size is 11mm.
    Crowsfoot end is hand filed for maximum clearance without sacrificing too much strength.
    The rear of the base is also relieved and curved for clearance, hand filed.
    There's the odd tool perve here as well as owners of DS with BVH.
    Please enjoy.
    cheers
    richo
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,412
    I admit to both: a liking for odd tools and owner of BVH.
    Last time I tried to make an open end crowfoot was about 10 years ago. It failed by spreading too much. The application was 17mm across flats for adjusting tappets on a Benz M130 engine. I made the mistake of using a cheap Indian donor spanner. I have learned much since.
    Roger
    It's how I roll...Brisbane
    33,952
    Me too, guilty.
    Nice one Richo.
    Every day when I wake up I reach up in the darkness with my eyes shut and if I cannot feel anything that resembles a wooden lid I know it will be a good day. No lid today.
    Jan 2006
    1,448
    I have two factory tools for that application, both by Hazet and both of different design.
    In the Benz application they are required to overcome a torque of approx. 27 ft lbs. Cheap tools won't quite cut it for that job.
    The open end spanner and socket used for the carby removal were Asahi "Made in Japan" and marketed by Repco in the 1980s. A decent quality and fit. One day I'll throw caution to the wind and start cutting up the 'willes! Not.
    r
    May 2011
    Lockrose, Qld
    93
    Next time I'm down in Tas I must grab a few pics of Dad's hand-made specials, not much Citroen stuff left, but he worked on all sorts of mechanical stuff.
    I remember he made the tool required to dismantle the front CV hubs on the early Citroen IDs, he had gas for heat, a hand built electric welder, a hammer and file. It should now reside with the Tas Citroen Car Club, I'm pretty sure that's where all his Citroen tools went about a decade or more ago.
    I must admit Richo, your tools have somewhat more polish than Dad often invested.
    mnm
    mnm is offline
    Croak croak... mnm's Avatar
    Dec 2010
    3,236
    You could always try here.... eh Richo!
    Matthew
    Jan 2006
    1,448
    Quote Originally Posted by mnm View Post
    Matthew
    Cheeky monkey
    I know (now) there's no Stahlwilles for sale there.
    r
    16,749
    This is how dodgy the stuff I make is in comparison
    Take a brake accumulator base and buggered jokey wheel and you can make up something like this ...
    spend a modestly small amount of money and buy one of those tecnosir regassers and a valve:
    inside the gassing head
    attachments to screw onto sphere plugs:
    and donate a chunk of $$$ to BOC for a nitrogen bottle, and your away
    10,192
    Quote Originally Posted by richo View Post
    I think my shabby effort was the shaft of a large rivet! Yours is rather more impressive.
    16,749
    Now I get it .... it's an upgraded version of this:
    Attached Thumbnails Attached Thumbnails Made a couple of D series tools.-p1160271.jpeg   Made a couple of D series tools.-p1160272.jpeg
    Los Angeles, CA USA
    1,955
    I am feeling really good about my home made sphere charging rig after seeing Shane's setup. I guess I should see if I can find some piccies.
