XM upper Strut mounts.
    Fellow Frogger! meinkiev's Avatar
    Aug 2011
    Kenya, Africa; Kiev, Ukraine, and Albury, NSW
    138
    Default XM upper Strut mounts.
    Does anyone know where I can obtain a pair of upper strut mounts for a 1992 XM (mechanic says it is Feb/1993 according to VIN No.?), 5 speed manual, 2 lt Turbo Petrol? And how much they cost?
    Mechanic says Citroen don't supply them now?
    Are the Xantia upper strut mounts interchangeable?
    All knowledgeable help appreciated!
    Shane
    Sydney, Australia
    308
    OMG people. Use the search function.
    Strut Mount rebuilds - XM and Xantia
    Garth.
    Fixin' Cit's.
    '19 308 GTi
    '15 DS 5
    '74 GS Convertisseur
    In the family
    '51 Traction
    '08 C5 X7 V6
    Previous ownership
    '95 XM V6 Series 2
    '96 306 XTDT
    10,192
    Do you know the difference between early and late style parts? Early have a rubber ring at the bottom, while the later ones have a metal ring where the early ones are rubber. This gives the centre of the strut mount a top hat shape and is meant to prevent it pushing right up and into the bonnet. The are not the same as Xantia parts.
    Being a 2.0 litre, it will have a different diameter to the garden variety 3.0 V6, but you need to know whether or not the struts have ever been changed and what part numbers are supposed to suit your car. I expect you will find the left mount is NFP for the 2.0, but the right mount may still be available from Citroen for the 2.0 litre. Not sure about Hydractive vs non-Hydractive porting though. I can tell you the RH strut top for the V6 appears to be unavailable and a French supplier was unable to get one for me last week.
    I think you may be able to find a new left one for the 2.0 litre if you look for cbg's advert from last year. A strut change to later V6 struts rendered the part surplus.
    Failing new factory parts, look for the crowd from Lithuania who re-rubber them. The UK crowd have been trying them, but I don't know what the verdict is at present.
    XM owners should now keep all old strut tops as possible rebuild cores.
    Aug 2011
    138
    Thank you guys for the help. I will follow this up.
    Aug 2011
    138
    I found the Crew in Lithuania Strut mounts who refurbish strut mounts and they did mine. It cost me $466 all up including postage each way for the mounts. the entire job, with hold-ups at both ends in customs, took around 6 weeks from memory. Could be much faster if things go to plan.
    Shane
    Sep 2003
    North Parramatta
    4,028
    Thanks for the update, Shane.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
