Help with a 2cv hood
    Feb 2006
    23
    Default Help with a 2cv hood
    Was wondering if anyone would be able to provide me with photographs and or setout dimensions for the location of the fixing points of the arm and brackets of the front part of the hood? By way of explanation, I am fitting a new model hood to an old 2cv which did not have the option to partially open the hood and hence no brackets above the windscreen and no folding arm mechanism. Thanks in advance! Paul
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,524
    Do you have the hood tensioning frame? This is the frame that fits the front part of the hood and flips back to give a sunroof effect. Have a look at this photo on the ECAS site:
    http://www.ecas2cvparts.co.uk/roof-t...od-p-1949.html
    I have taken some photos of my 2CV. If you have a genuine frame as above, I can go and measure where the bracket screw holes are in the body and take a photo of exactly where the frame ends in relation to the body/windscreen. Remember the existing bracket screw points have captive nuts. If your vehicle never had a frame, you could try self tappers to hold the bracket in the first instance. There is a fair bit of force on the brackets when tensioning the hood.
    Took a photo showing location of bracket (drivers side) and distance of screw holes from the inside frame of the windscreen lip (270mm and 310mm respectively).
    If you don't have the frame, the easiest is to procur one from either 2CViking in France or Ecas. The only downer is the freight because of its dimensions.
    John
    Sep 2012
    France
    37
    Paul didn't you receive the closing H bracket etc? See this http://www.mehariclub.com/images/art...apote_2cv1.pdf
    Feb 2006
    23
Name:	Hood Brackets.jpg
    John
    Thankyou very much John! Will proceed with confidence
    Feb 2006
    23
    Yes, thanks Cpt Viking - thanks too for the article. P
