DS radiator pipe.. have you checked yours?
Results 1 to 8 of 8
    mnm
    mnm is offline
    Croak croak... mnm's Avatar
    Dec 2010
    3,236
    Default DS radiator pipe.. have you checked yours?
    Greetings all
    I finally got around to replacing my lower radiator pipe yesterday... never got around to checking it since I bought the car and I had the new bits ready to go... well thank goodness I changed it... have a look at the guts of the pipe.. looks like a cave or something..eeeeewwwww...
    Replaced with a stainless pipe and both rubber joints as well and made sure there was enough clearance above the steering rack pipes..
    Matthew
    8,257
    Quote Originally Posted by mnm View Post
    Greetings all
    Matthew
    Tick* done that and stainless, painted brown 'cause the one it replaced 'twere brown, those horrible hose clamps won't be there much longer either
    Certainly provides incentive to use a stocking in your top radiator hose to catch the crud that must be running through the cooling system.
    BTW, Denise says if you don't get that filthy piece of crap off that table quick smart they'll be no Tim Tams for 6 months!!!
    08 C5 X7 HDi very Noir
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,448
    Good example of corrosion.
    PH balanced coolant, replaced regularly and perhaps even a magnesium sacrificial anode will keep things in good condition. Stainless steel is also at risk from corrosion, don't let the shiny stuff lead you to a false sense of security.
    Lotsa luvly brown paint there Chris, typical of the late model cars.
    cheers
    r
    mnm
    mnm is offline
    Dec 2010
    3,236
    Interestingly Chris it looks flakey but the little stalagtites and mites are rock hard. Tim Tams are off the menu... I have to fit back into my uniform next month! I have however made two batches of pistachio and cranberry biscoti lately!
    Hello to Denise xx
    Matthew
    Fellow Frogger! deesse's Avatar
    Dec 2010
    Melbourne Australia
    571
    are they the little bits of rock hard crud from the radiator hose or the biscotti.
    sorry I couldn't resist. enjoy
    cheers Tony
    mnm
    mnm is offline
    Dec 2010
    3,236
    Quote Originally Posted by deesse View Post
    cheers Tony
    Sooooo cheeky! No biscoti for you then!
    Matthew
    Dec 2010
    Melbourne Australia
    571
    you have to admit the lighting is not up to your usual flattering standard
    mnm
    mnm is offline
    Dec 2010
    3,236
    Agreed.. the ipad camera is crap. I suppose you can have one piece...
    Matthew
