C4 aircon condensation
Results 1 to 2 of 2
    bega
    158
    Default C4 aircon condensation
    This has probably been raised before, but searched and could not find, therefor....
    My 2006 C4 suddenly had the passenger's footwell full of water after a fairly long trip.
    Definitely not coolant, must be condensation from the airconditioning, which, I suppose, means that the drain hose is blocked. Anyone knows where to look for the outlet of that drain?
    Thanks!
    9,769
    Assuming it's under the carpet, then there's a drain either side of the heater box and they look like a rubber elbow leading to the floorpan. The elbow may have collapsed and needs some support to keep the tube open or the flaps of the drain itself are stuck and not allowing the water to drain. If it's on top of the carpet then it's leaking somewhere else - window seal? Heater box?
