Repowering a CX
Page 1 of 3 123 Last
Results 1 to 25 of 56
Thread: Repowering a CX
    Fellow Frogger! andrewj's Avatar
    Margate
    395
    Default Repowering a CX
    Driving around over Christmas / New Year in the CX, I couldníthelp but notice just how bad the fuel consumption is.
    Why not transplant a modern, single rail turbo diesel?
    Presumably a gearbox/engine combination from a modern front wheeldrive would be logical, with customer drive shafts and engine mounts formingthe interface between the old and the new.
    A C4 is almost an identical weight to a CX sedan (1290 vs1300). So a 1600HDI should give adequate power and torque. Hopefully a smallerdonor vehicle would also maximize clearances in the engine bay.
    Fuel consumption would improve from around 12-15l/100kmshould improve to 4-6l/100km
    Whatís the catch?
    Driving - '90 XM, '85 CX IE Auto, 406 Coupe, 405 srdt wagon, '78 dyane, Resting (or Rusting): '73 Birotor '82 CX Presitige, '81 CX Break IE, GS X2, GS1015 Wagon, GS 1300 5sp Wagon, '76 GS 1220 Wagon, '75 GS Wagon, '58 2CV, '58 Vauxhall Velox
    1,475
    Andrew, what kind of fuel consumption are you getting from your CX IE auto? Having owned two, I used to get 15l/100km at best. I am a self-confessed lead-foot or more politely, an affirmative driver.
    I've heard and read about all manner of possible conversions: 20B Rotary, C114 Maserati (from the SM & Merak which was proposed among many other engine possibilities before doing what they did with the D and simply threw in what Shane calls the "tractor motor") and local folklore has it that there's a CX around Brisbane with a Skyline engine. All of these possibilities would certainly up the power and fuel consumption.
    1972 SM
    1989 BX 16 Valve
    12,278
    15l/100
    604's do better than that in bad tune
    if i was ever silly enough to own another CX i'd look at sticking a TD out of a 405 in one
    simple and economical
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    CitroŽn Tragic UFO's Avatar
    9,785
    IIRC, there was talk of a CX at the Cit In in Renmark many years ago that had a Nissan engine in it.
    The biggest challenge would be fitting the hydraulic pump etc - I suppose.
    10,097
    You may be better off with a 2.0HDi set up for a manual gearbox and taken from some Pug. Getting a working engine manangement system would be the likely challenge. Its also used in other things like a Mondeo, so a Ford donor may even be easier to work with.
    Fellow Frogger! deesse's Avatar
    Dec 2010
    Melbourne Australia
    571
    just leave it be but drive a little less. Like the easiest way to lose weight - eat less rather than excercise more
    cheers Tony
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,445
    The catch?
    The amount of money spent, (not to mention the time) would exceed any return in fuel saving.
    If fuel consumption is a major priority, you're enjoying the wrong car
    16,702
    get a petrol turbo one ....... the fuel economy is a lot better if you can keep your foot off the "go" pedal. Especially compared to the slugomatics. I think most CX's that get anything remotely close to 15L/100km must be in a really poor state of tune (even if they seem to run ok) and are leaving trails of fuel down the road from a leaky tank and leaky brass fitting pushed into the carby.
    I reckon the best would be the 2litre HDi from a 407 ................... That way you'd get the 6spd manual gearbox with it I'll give it a crack if a tree of something destroys the 407 here .... I'd just need to find a good CX wagon bodyshell.
    Tadpole CX Series 3's Avatar
    Jun 2011
    Vancouver, BC, Canada
    18
    I intend to drop in a Tesla drivetrain to create an electric rocketship. This is one of projects I'm looking forward to doing after I "retire" in about 5-10 years.
    12,278
    i'd still go the 405 diesel engine
    less computer trickery involved and a more conventional engine to work on and around and still return great economy
    1 x 2018 3008
    Fellow Frogger! Fingers's Avatar
    Old Junee NSW
    584
    Or the obvious... a CX diesel??
    Feb 2006
    Brisbane, QLD, Australia
    515
    Default Re: Repowering a CX
    Cx had the best diesel at the time. Maybe that would be the answer.
    CX Register
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    631
    Have had a good look at putting a 406 hdi and manual in a cx but encountered a few issue that make it a lot of work
    i have a cx wreck and a 406 wreck side by side to compare
    the biggest problem is the chassis cross member in the cx, it sit up high and across the top of the differential and the engine leans forward from under it, the 406 has the engine leaning backwards ( this could be tilted but oil supply and oil drainage need to be adressed) and the gearbox would need to remain level, also the 406 engine has the turbo etc at the rear right where the cross member is, i also measured the distance between the drive shaft and crank shaft on both engines and boxs and the cx has about 120mm larger gap making the 406 box very hard to get the drive shaft lined up straight which is crucial is you dont like torque steer. the only option in regard to fitting a hdi would be grafting it to the cx box and finding a cx diesel final drive to get the ratios right and then getting the computer to work with the engine outside of the 406
    everything can be done but at what cost
    my cx does 10.5 ks per litre which i didnt think was to bad for a heavy car with a vintage tractor motor
    1,475
    Feathering the accelerator may still be the cheapest option going.
    1972 SM
    1989 BX 16 Valve
    Oct 2011
    Toowoomba
    650
    '80 CX Cmatic carby. Best, 40 mpg. Worst, 14. average, 26mpg (about 11.5 l/100 km) carby manual we were running averaged 32 mpg over 100,000 miles.
    I have also looked at fitting the 405 SRDT, by re-doing the turbo installation (move to front) and using a Xantia belt drive pump, however the next CX projects are both 25 IE's which give good mileage if driven appropriately. Being in the country we can use the car's inertia and low drag. Can't do this driving in traffic.
    The webber carbs can have problems, from the little plugs in the various drillings moving around. Had two do this so they couldn't be tuned to idle any more. This dropped the economy from 32 to 26 in the manual car for a few weeks until we fitted another carby.
    There isn't an issue converting a carbie to injection with megasquirt, adaptronics etc. as the cylinder heads are the same for carbie and IE, just need to hunt up a suitable manifold, plenum & throttle body. Any jap plenum should work (pintara, magna etc) and get a plate and stubs made up to match the head if you can't find a Citroen one.
    The basic engine is about the best engineered I've seen (better than mercs and BMW) put a warmer cam and an ECU with knock sensing and a five wire O2 sensor and you'll get the sort of efficiency you'ld expect from a modern car of the same weight without all the hassles of re-powering it.
    Bruce.
    Best of luck.
    11,211
    Quote Originally Posted by donat View Post
    I agree! When I realised how much fuel our CX used I just stopped thinking about it. Cheap and easy solution.
    Every now and again I do think Megasquirt though. The thought of serious surgery with a different power train was for me in the "nice cuppa and a Bex and a lie down" territory.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,156
    I think I'd be purchasing a second economical car for city use and saving the CX for leisurely country cruising. They are all getting a little long in the tooth for regular everyday transport and commuting. The are also at the stage of ''naisance'' to classic status and deserve preservation! Re engining appears to me to be sacrilege.
    Cheers Gerry
    10,097
    I can't see an economic argument that can justify the work involved. If you want to do it or need to change the fuel source, fair enough, but otherwise, it's really a non-argument. Keep the CX, use it less and buy a used Xantia/C3/C4/C5 HDi, which can now offer very good value for money. To make a transplanted drivetrain work as well as it did in a late model donor vehicle, you are going to have to invest more time and money in the management system than anticipated, particularly with an automatic. Using a drivetrain taken from something earlier without the complex electronics would make the idea a much more manageable proposition.
    Fellow Frogger! rubyalpine's Avatar
    Christchurch, New Zealand
    490
    Complex conversions usually (always) end up far more costly than originally estimated. If you did end up with better fuel efficiency, it will probably take about ten years to re-coup the cost of the conversion.
    My suggestion: Fit a double cone pod filter, freeflow exhaust, pump up the tyres a bit harder and drive conservatively!
    Henry
    1,475
    While we're on the subject of fuel, what's the Birotor like on consumption, Andrew?
    11,211
    NORTH PERTH W.A.
    853
    I look at the CX then at the Cadillac and think 300kw of all meaty american goodness and a motor that is 20 kilo lighter maybe after the next hail storm
    Also thinking would bolting the T2 turbo on to a 2500 ie blow up the trany straight away ?
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    The easiest route to better economy would be going to a mapped injection system like a modern car has. Plenty of fiddly work there but nothing impossible. Much easier than trying to replace the perfectly good motor mounted in its unique way. What could you expect, probably comparable to a Xantia so about 8.5 - 9.5 around the city if driven with restraint. Probably get into the 7s in country running.
    Or you could do as has been suggested and buy yourself an economical runabout and drive the CX a little less. That is what I have done.
    If economy is a big priority and you would still like to repower the CX why not get the drivetrain out of a Camry Hybrid. That would give the best result for all the work involved. The cutting edge nature of the drivetrain would sit well with the avant guard nature of the CX to.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Margate
    395
    Do you remember Sir Humphries "most efficient hospital" from the yes minister show?
    A bit like that really- as it is can not move under it's own steam, fuel consumption is exceptionally low.
    When it is working it is around 13L per 100km - about the same as a CX, but much more fun
    16,702
    Quote Originally Posted by Greg C View Post
    good move ... you forget how good the CX is unless you have modern crap to drive to compare too.... I suggest something like a 407 .... it'll make the CX feel brilliant in comparison
    I'm thinking of getting another car so I can have 3 cars to drive over the year on club permits (in place of one fully registered car). I'm thinking, cx turbo, ID19 and something like a V8 Range/Land rover with a 4ton tow capacity Fuel economy isn't relevant if your only using it 45days a year
