DS not running,no hydraulics, how do i keep suspension up to move vehicle
Results 1 to 25 of 30
Like Tree2Likes
Thread: DS not running,no hydraulics, how do i keep suspension up to move vehicle
    Member levit8's Avatar
    Aug 2005
    South Aussie
    112
    Icon11 DS not running,no hydraulics, how do i keep suspension up to move vehicle
    hey guys,
    recently bought a late d sedan but its a non runner and hydraulic hoses are broken so cant use a drill to
    raise vehicle with hydraulic pump
    so basically after advice, tips etc on how to keep the body up so i can move it, load and unload from a car trailer from anyone who has done this before (or any links to info)
    any help appreciated
    jeff
    NORTH PERTH W.A.
    853
    Find a witch steal her broom stick.
    Cut into 50mm lengths.
    Jack car up to high remove suspension spheres,
    insert pieces of said broom stick in ram tubes,
    refit spheres or temp caps and you have a high rider with no suspension.
    Note you still have no brakes or power steering and caution tie car down by wheel straps or to suspension arms as body pick up points are very very weak,
    good luck
    16,702
    Get a standard trailer (no beaver tails or tilts ... they suck). Most trailers these days have decent length ramps as modern cars are quite low. Chock all 4 trailer wheels and unhook the trailer from the car. As you winch the DS onto the trailer, the weight of the front of the car will tilt the trailer towards the sky, as the car rolls on, the trailer will slowly lower itself back down onto the towball. This should load most D
    s onto most trailers.
    Aug 2005
    South Aussie
    112
    ok forgot about the sphere removal tip, have been told that before but yet to try it
    also appreciate trailer trick but last time i done that ended up putting a big dent in my mates hq panel van tailgate
    when trailer decided to move
    will try broomstick method first as loading should be straight forward once i have ground clearance
    thanks guys
    CitroŽn Tragic UFO's Avatar
    9,785
    This was a subject of discussion on here just last week.
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    631
    I have done in multiple times just like shane but i dont unhook the trailer instead i reverse the tow car backwards up some car ramps which make the rear of the trailer almost hit the ground then just winch it on
    16,702
    Quote Originally Posted by levit8 View Post
    thanks guys
    Um... you need to chock all four wheels like I suggested
    9,785
    Does the link to your pics and explanation still exist?
    16,702
    Gee's ... look how shitty digital camera piccies were back then
    http://shanescitshed.com/deadcit/deadcit.html
    I should update that webpage someday. I should stick on youtube how I load flat hydraulic cars onto the car trailer here ...... You don't have to be insane, but it does help
    Sheffield/Tasmania
    631
    one thing you missed shane, when the trailer has drop back onto the ball make sure you lower the hitch handle before driving otherwise there will be a disaster
    16,702
    Quote Originally Posted by Balki View Post
    Yep, and the safety chains and wiring connector. It would probably pay to tie the car onto the trailer and remove the ramps from the back too
    It's how I roll...Brisbane
    33,702
    And give the poor broomless Witch a lift home...
    9,785
    Quote Originally Posted by 59 Floride View Post
    She should know how to get home without a broom. You shouldn't have to spell it out for her.
    10,097
    Not a homing witch?
    You are best to get some dead late spheres as the broomstick can damage the sphere damper if you are not careful. It also needs to be a very clean broomstick to avoid debris in the cylinders. Most of the weight of a complete DS/ID is in the front, so take that into account when trying to winch it onto a trailer and jacking it.
    Also, don't tie one of these cars down to a trailer by the body if it can be started by anyone forgetful or just not understanding the system. Car transporters could make this error and then rip the body towing points etc. out when the car tries to self-level. Tie it down by the wheels plus safety chains on the suspension.
    Aug 2005
    South Aussie
    112
    will do the broomstick trick but was going to put flat washers at either end to hopefully take pressure off ends of broomstick
    thanks again guys
    Fellow Frogger! Mort Subite's Avatar
    620
    Not a homing witch?
    You are best to get some dead late spheres as the broomstick can damage the sphere damper if you are not careful. ....
    Aha, that's what I have been told and I've seen a couple of pressed damper spheres ruined this way - you can see the damaged 'shim'.
    I wonder how the cars were set-up during motor shows, or were they flat on the ground?
    CITROEN CAR CLUB of NSW - MEMBER. www.citroencarclub.org.au. . .www.facebook.com/CCCNSW
    08FD DSPECIAL "Dear Prudence wont you come out to play?"
    00FF7512 DS23SAFARI "Pull up to my bumper Baby, in your long black limousine."
    C2MY06 C2VTR "Go speed racer, Go"
    YDO005 MORRIS MINI DELUXE "The Mini Deluxe floats on fluid too"
    NORTH PERTH W.A.
    853
    Quote Originally Posted by Mort Subite View Post
    I have a set of water pipe sections ~45mm long and from memory about 25mm dia and some machined aluminum strut caps result no damaged spheres but I have to move a few dead ones around
    Aug 2005
    South Aussie
    112
    just want to say a big thank you to everyone for there advice and especially Shane L. for his almost taking offense to my lack of enthusiasm in testing his unhooked trailer method which motivated me to look into it further
    basically could only remove one sphere to do the broomstick trick so tried doing it his way
    actually worked amazingly well for both loading and unloading
    only thing extra i done was kept trailer chain hooked up and that served to limit and hold the trailer stable at a critical stage (as well as
    wheel chocks)
    so car is relocated, nothing was broken, nobody was hurt, all good
    thanks again
    Feb 2012
    Ongar / England
    868
    Any pictures?
    May 2012
    393
    wheel chocks)
    thanks again
    Hi there,
    I too followed Shane's post to retrieve an ID19 and it worked a treat. Thanks Shane for all your contributions and the inspiration of the "best ever ID" thread.
    Leconte
    1962 Heidelberg ID19 "Axel"
    1965 Heidelberg ID19
    half owner 1974 GS 1220 Convertisseur Break
    Oct 2011
    Toowoomba
    650
    16,702
    wheel chocks)
    thanks again
    I didn't take offfense I've just tried loading most ways and that's the only way I've found that is almost always successful Owners usually stick the cars under trees or some place that doesn't allow access for jacking/lifting too (dunno why we tend to do that ). Lifting to use broomsticks can sometimes be quite difficult. Especially if the rear spheres refuse to come off, and the rear arm area is frail... and the cars sunk into the ground ... and there is nowhere for a jack to get under ...etc, etc.
    That's how my trailer works too... it has a long overhang at the back, so basically "automatically tilts". It's quite amusing to drive a car with dead hydraulics up the ramps... as you get to the back edge of the trailer the rear wheels of the towcar lift off the ground (even if its a weighty 4wd) ... then the tow car lowers back down onto the ground as you roll onto the trailer forward of the trailer axles.
    I should post a Utube video of the "self loading" trailer some day
    33,702
    Here's how German supermodels load a DS onto a trailer.
    Los Angeles, CA USA
    1,955
    I'd like to load her trailer.
    doing the daffyduck dance with the aussiefrogs app. woohooo woohooo woohooo.
    Member twistedeez's Avatar
    Mar 2011
    Byron Bay
    114
    Bloody hell! She's done more than one. Er videos that is...
    Out of the 1992 Saab 900 turbo and into
    1989 Citroen Bx 16v
