Towing a DS
Results 1 to 20 of 20
Thread: Towing a DS
    Fellow Frogger! Inspector Clouseau's Avatar
    Dec 2002
    North Coast NSW
    191
    Default Towing a DS
    Just about to head off on a little DS Christmas sojourn - sleeping in the Safari. It occured to me that I don't know the answer to a basic/dumb question: what do I do in the unlikely event that I can't get the car to start? I don't imagine a tow truck would help, nor a tilt tray. What is the recommended strategy for towing a non-pumper?
    Martin
    Los Angeles, CA USA
    1,955
    No problem to load a dead one onto a tilt tray.
    When I was a kid, I saw my parents push one dead one with a live one a couple of times. 40 miles!
    It's how I roll...Brisbane
    33,721
    Any Renault would be more than suitable for a tow vehicle...hope this helps.
    CitroŽn Tragic UFO's Avatar
    9,789
    Unless there is absolutely no other way to get around it, you should never tow a DS with only one set of wheels on the ground. The car will have no suspension and being the age that they all are, the resultant damage could be more than you wish to see.
    A modern flat bed truck (the NRMA etc call them an "all up lift") will easily pull the D onto its tray. The towie should know to link their winch hooks around one of the front leading arms on each side. Once the car is on the tray then the straps can be put over the front wheels to hold it on. They should also only use the rear "tow" hooks as locators not tied down anchors unless you want the arse of the car pulled off.
    The one time my D has been on a flatbed (while I've owned it) was because of a clutch linkage problem and I was not then confident to drive it home over many hills, through a busy suburb then up a freeway to home. However, I could start it, which meant that when the truck arrived I could life the car to full height preventing any chance of a scrape, but the towie said it would not have been a problem anyway.
    Others will add more info I'm sure.
    By the way, while some may bemoan the way the NRMA etc have become, their levels of premium coverage are well worth the price.
    8,249
    Icon12
    Quote Originally Posted by 59 Floride View Post
    You guys would have seen plenty of action towing dead Renolts, I guess your cardigans with reinforced leather patches would make great tow ropes too
    08 C5 X7 HDi very Noir
    "Dťesse" Roland Barthes, 'Mythologies', 1957
    The Dťesse has all the characteristics of one of those objects fallen from another universe that fed the mania for novelty in the eighteenth century and a similar mania expressed by modern science fiction: the Dťesse is first and foremost the new Nautilus.
    9,789
    AF definitely needs a "I really got a chuckle out of that one" button. There is enough "Likes" in the world with Facebook and Justin Beaver head and his wannbees.
    Mar 2005
    920
    It must be stressed that while the D is dead it MAY have no power steering for long OR brakes....the brakes SHOULD be the last thing to go...... So it is imperative to mention that the car will not be able to be stopped or even slowed during any manoeuvering..so it will need to be "assisted" into position and out of position.
    The obvious lack of ground clearance can mean some underneath damage to panelwork and exhaust etc.
    Then there is the possibility of the steering lock being difficult to release as the steering will be stiff and hard to turn.
    The NRMA man may not be aware of the DS's ability to keep all systems operational only happens with the engine driven pump actually pumping. In extreme cases it may be more useful to remove the spark plugs and tow the car in gear till height is restored ( and therefore full braking at least.) ...
    33,721
    And a "D'oh!" button would be handy as well...
    Dec 2002
    North Coast NSW
    191
    Thanks all, very informative and fun. As for:
    'Any Renault would be more than suitable for a tow vehicle...hope this helps.'
    A Touche Button might have been useful too.
    San Diego, California, USA
    3,543
    Well, DUH.....that is, if the Citroen you plan on towing isn't any bigger than 1/18
    9,789
    Good point by fritzelhund.
    Oct 2003
    canberra
    870
    Of course if it was a flat battery problem and you could jack up one front wheel and rotate that wheel in gear manually with the ignition on, with luck it might start.
    Mar 2005
    920
    Quote Originally Posted by alpine View Post
    Mais non ! a 4 speed DS has a crank handle !!!
    Even a BVH has a crank but 5 speeds and the B/W autos are not so equipped.
    11,231
    Quote Originally Posted by Inspector Clouseau View Post
    Martin
    Apart from all the jocules, isn't there a wheel bearing issue too? I'm sure I've read somewhere that they can be damaged if the car isn't strapped down. If anyone knows, and can explain why, I'd be very interested to know.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Feb 2012
    Ongar / England
    868
    Hello, there is a sticky on the Citroen Car Club forum
    http://www.citroencarclub.org.uk/dru...php?f=6&t=5027
    The UK forum is open to all now, just have to register
    Jul 2003
    317
    I have only ever payed for sex once.
    Many moons ago i received a late night 'booty call' from an ex-girlfriend at around 1am, I jumped into the DS and screamed across town as fast as the old girl would take me.
    Let's just say she was well prepared and I was in for a real treat.
    After a few hours sleep she got up and went to work and I got to sleep in, perfect right!
    I left just before 10am as i had parked in a clearway that was about to start. I walked out on to the street only to find a tonne of traffic and no DS !?! Well the clearway ended at 10am and not started, I guess my mind was bent on something else tithe time.
    The guy at the impound couldn't understand why I was so happy with myself. I asked him how they moved it, off the back of the truck with the front wheels off the ground... I looked underneath, no obvious damage, but I did have to repair the bump stops years later...
    After the taxi ride and impound fee the night cost me $480, money well spent!
    Harley
    Don't remind me!
    16,609
    Now that's a proper reminiscence!
    Feb 2012
    Ongar / England
    868
    Got any pictures?
    1,475
    By the sounds of things, the DS kept it up all night (for it to be towed the next morning). Great story.
    1972 SM
    1989 BX 16 Valve
    Feb 2002
    Coolum Beach
    2,048
    Bet YOUR spheres were flat after a night like that!
    DS Un jour, DS toujours !
    C3 II 2010 Automatique AL4
    Everything's gone bloody automatique!
