'03 C5 Engine immobiliser fault
Results 1 to 7 of 7
    Member redsky's Avatar
    Northern Vic
    32
    Icon8 '03 C5 Engine immobiliser fault
    Following a flat battery last night, it put a fresh one in & the above fault code appeared, and of course, the car won't start!
    Is there a reset procedure for the ECU or similar that i can try?
    I'm 200km from the Citroen dealer, so it's a bit far to push...
    thanks
    Darren.
    Aug 2005
    Merimbula, NSW, Australia
    323
    Default Re: '03 C5 Engine immobiliser fault
    You could try re-syncing the key.
    1. Turn Ignition ON.
    2. Press and HOLD the LOCK button for 5 seconds.
    3. Turn Ignition OFF.
    4. After 5 seconds test remote key.
    Leon
    1987 Peugeot 505 GTD
    2010 Citroen C5 3.0 V6 HDi
    10,115
    Some of the early diesels would not fire after you disconnected the battery. I found that out after thinking I'd killed the car when adding an extra wire for the fuel pump feed at the fuse box. Nervous moments, but locking and unlocking the car fixed it. Try that.
    Northern Vic
    32
    Thanks guys i'll give those ideas try.
    Northern Vic
    32
    Nothing Worked, yet another trailer job to the Dealers next week.
    Feb 2011
    brisbane Au
    940
    Quote Originally Posted by redsky View Post
    thanks
    Darren.
    Hi Darren, any dash lights with ign on?. Was the battery new-fully charged. If you have fault reading we'll assume things are receiving voltage but how much. Does the engine turn over but won't start? if so fuse No8 probably blown. Won't turn over? probably immobiliser fuse under fuse box. Anyway something simple I reckon.
    Cheers.
    Don't remind me!
    16,609
    Darren, what's the reason for not owning a Lexia?
