15-6 brake parts availability?
Results 1 to 9 of 9
    Los Angeles, CA USA
    1,955
    Default 15-6 brake parts availability?
    I have been charged with turning that HY from Area 52 into a driver.
    I have been told that the brake parts largely cross over to the 15-6.
    My questions are: Are there a lot of 15-6 in Australia?
    Was the 15-6 sold there?
    Am I correct thinking that wheel cylinders will probably come from France? Or is it possible that somebody down under has a good stock of brake parts?
    Something tells me I am going to need 6 wheel cylinders and some new hoses at least.
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,446
    Give this link a whirl Wally.
    http://www.ctaservice.nl/c-1321-15cv...peFilterID=115
    There's not many of the 15/6 in Oz, a rarity.
    10,102
    Isn't there also the difference of the fluids used? I know Tractions used brake fluid, but I thought the HY used LHM.
    Try this: http://www.citroworld.com/tableaux/i...=33&itemId=258
    San Diego, California, USA
    3,543
    Thanks for the heads up David, but the H in question is a '53.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,157
    Cheers Gerry
    Jan 2006
    1,446
    Wally, Citroworld in the Netherlands will also have HY brake parts.
    I misread the initial post, looking at 15-6 rather than HY.
    Fellow Frogger! tractionfan's Avatar
    280
    The front brakes on a 6 cylinder are double leading so if it's the same there should be 2 brake cylinder each side on the front. Can't you send them to a brake specialist and get them machined and have stainless sleeves put in them. that's what i did with mine also if the shoes are in reasonable order you should be able to get them reshod.
    3,157
    Quote Originally Posted by tractionfan View Post
    I went this route with my 6H and had problems with leaking cylinders. The seal between the sleeve and the original casting has to be perfectly machined and then must be pressed in with a sealing compound that will set and form an impervious barrier to the hydraulic fluid. The fellow doing mine got it right after the third attempt. Each time up to the third attempt, a set of bonded linings was ruined by fluid saturation. and had to be replaced.
    You stand warned!!!!!!!!!
    By the way HY drums and shoes are wider and so is the wheel bearing.
    Cheers Gerry
    280
    H
    You've had some bad luck Gerry. I've done this with both my 6 and my Normale. I haven't had trouble with either.
