HELP......Lost my only ignition key for Citroen Pluriel
Results 1 to 12 of 12
    1000+ Posts dogboy's Avatar
    melbourne,victoria,australia
    1,374
    Default HELP......Lost my only ignition key for Citroen Pluriel
    Jens pluriel keys have found the bermuda triangle that exist's around our house.....
    No spare key..just a spare fob case...and I can't find the books for the key number !!!! aaarrggghh
    does anyone know if a key can be cut from the VIN number??
    Cheers and Thanks
    Rev. Dogboy
    1969 DS21 Pallas BVH with leather
    1970 Renault 16TS
    1967 Honda S800 cabrio
    Citroen 1966 ID Safari (with 23 running gear)
    1975 VW Kombi poptop
    Porsche Boxster S manual
    1988 Vespa PX200E
    Don't remind me!
    16,609
    Yeah; easy-peasy. Get onto "xmaffyx" on UK Fleabay and he'll give you the key cutting code plus the ECU unlock code for programming the key, for about four quid.
    Pretty sure it's a chip key.
    1,374
    cool... Thanks Addo...I had looked on uk ebay but the seller I found said I would need the key code or the origional key they could cut it from
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=250866524005
    this is my type of key
    Rev. Dogboy
    1970 Renault 16TS
    1988 Vespa PX200E
    Don't remind me!
    16,609
    Almost positive they're a chipped key. So once its arrived you need a bod with Lexia to plug in and code the new key. Otherwise it will key lock and unlock, and crank over but won't start.
    Matt is very quick on the codes usually - if you paid now you'd have it tonight.
    p.s. At that price for the cut keys, I'd order two!
    1,374
    I have this Citroen card with a magnetic stripe and a picture of a key...looks like you swipe a key over this card???
    strange..
    I have the spare fob...won't that be already programmed...has the circuit board inside
    Have also called Citroen Brisbane who may be able to help from the VIN
    I still need the blade though....
    fun and games
    Rev. Dogboy
    1970 Renault 16TS
    1988 Vespa PX200E
    Don't remind me!
    16,609
    Does the card have a scratch and sniff panel in the bottom right corner? If so, your four character BSI programming access code is under there. This is a combination of numbers and letters with no "i" or "o" to avoid confusion with ones and zeros.
    The remote and chip are two different things. Normally the key blade and chip (often not much bigger than a grain of rice) go together - the chip works with the immobiliser in the ECU, but its passed through the BSI.
    The keyfob sends a radio signal to the BSI that operates the central locking. It doesn't allow an unrecognised key to start the car.
    16,702
    Your local Citroen dealer will get a key for you. You will need to flat tray the car to them to program the key in though. Poogoes keys were about $515 each. You NEED a second key too. If you ever loose the key the car is imoblised and stranded at it's current location without a spare
    1,374
    the panel says security and runs the whole way across the card.. hand written on the card is C1067
    Rev. Dogboy
    1970 Renault 16TS
    1988 Vespa PX200E
    1,374
    worst thing is the keys are in or around the house !!!!!!!!!!!!
    Rev. Dogboy
    1970 Renault 16TS
    1988 Vespa PX200E
    CitroŽn Tragic UFO's Avatar
    9,786
    Look on top of the fridge, in the freezer, the mailbox... you know, all those usual places.
    Around our place you come in the front door and you put keys where they belong immediately. That way one cannot be told "it's where you left them".
    Don't remind me!
    16,609
    I have four keys for the Xantia.
    Touch vinyl, never lost a car or house key but in one week at work managed to lose both a swipe card and a master key!
    1,374
    and to top it off the water ran out...fine I think...I have a back up storage tank....but NO the pump won't start to transfer the water to my main tank!!!
    exhausted after 2 solid days of turning the house/outbuildings upside down....
    and then this afternoon I get a call that the keys have been found at the local shops..
    Jen had driven there with the keys and somehow they have fallen out...
    A lesson learnt and a key will be ordered (if I can find the key code!!)
    Rev. Dogboy
    1970 Renault 16TS
    1988 Vespa PX200E
