Eolys additive problems
    Jun 2004
    Mackay
    33
    Default Eolys additive problems
    In a current thread, David S (referring to Big Kev's C5 2.2TT) states that some of this model had "Eolys additive problems".
    Perhaps David S and others would be kind enough to elaborate on this. I have been unable to find any info by searching or googling. I did not want to hijack the other thread, hence this new one.
    Thank you. Rossie.
    10,128
    Simply where the fuel filter became blocked early on and the Eolys might have been partly blamed. So, you might check for a blocked filter because it's relatively easy and cheap to do as part of normal servicing, but that isn't saying there is an ongoing and endemic problem. There isn't and it's one of the better C5 models you can own.
    Jun 2004
    Mackay
    33
    Thank you for that, David S.
    Fellow Frogger! Fingers's Avatar
    Old Junee NSW
    584
    There was a recall, but a fluid replacement was pretty much it from memory.
