Disconnect carb heat
Results 1 to 14 of 14
    Feb 2011
    230
    Default Disconnect carb heat
    has anyone disconected those exh tubes to the carb base
    as they boil the fuel in the carb in summer
    and are a pain , just runs too hot ,
    Ive got a thick bakelite spacer between carb and base and it still get too hot
    I think I will just take the carb up a bit on a tube or something to get it away from that stupid hot mount , it s hot start is terrible , what do you guys do
    Don't remind me!
    16,609
    EFI? That'd solve your fuel vaporisation issues. Pretty sure PastiŮa has got his car sorted way - assuming you are speaking 2CV.
    Feb 2011
    230
    Idea
    just cut tubes and seal them , then in cold weather when the carb ices just duct in hot air from the heaters like planes do with a cable and hose into the air cleaner , solved ,
    Feb 2011
    230
    Default Efi
    Too expensive and up market for a DUCK
    8,378
    How about fitting some sort of tap inline and manually restricting the flow.
    That way you could still warm the area a bit and if you found yourself in a situation where the carb was icing up you could simply bump up the flow without needing tools.
    jo
    It's how I roll...Brisbane
    32,913
    Renburg,
    You have an insulator between the carb and base...have you got an insulator under the mounting nuts as well, these can transfer a lot of heat to the carb...if you haven't it might be what's causing the problem..?
    9,670
    jo
    Yes, a cable operated Heath Robinson air flap, controlled by a discarded lawnmower throttle cable and lever would be quite in keeping with the little duck!
    tweed heads
    1,483
    The first GS i baught had an exhaust leak from under the carb strange ! just plugged them up with welche plugs .but im from warmer climes ,no problems in winter ,PUGS
    Feb 2003
    Sunny Melbourne
    79
    Somehow, i cant imagine those tubes are causing vaoprisation problems at this time of the year.
    The original cooling system works very well
    I would look elsewhere in the cooling system.
    Is the fan ok, no chunks out of any blades,
    is the engine clean and free of grease,
    is the oil cooler clean,
    is the air flow free from obstuctions.
    is the air filter in good condition,
    are the barrel and cylinder head cooling fins clean and grease free?
    A 2cv in good condition should run comfortably in over 40 degree weather.
    Feb 2011
    230
    Default YES Yes
    Quote Originally Posted by 59 Floride View Post
    Renburg,
    Will do thanks
    And oh yes the cross over EXHAUST at the carb is needed for good exhaust efficiency reasons
    so I guess just keep it connected
    but not actually going thru the carb mount ,
    hellish hot !!!!!!!!!!in Summer no good
    Light aircraft really do have carb heat for anti icing
    Feb 2011
    230
    Unfortunatly , the old I dont have time , for mods
    its going hard tomorrow , in hot weather , its mainly good but I just expect fuel injection type starting , mmm
    also the idle mixture plays a part here , dont know what sort of part though
    Feb 2011
    230
    Default Well
    I will just refine my heatsink a lot more with a different material and shape , but what material
    Coffs Harbour, NSW, Australia
    615
    While you're at it, why not fit the Victa motor too ? Hot weather doesn't worry them & it might go faster !
    Jul 2003
    317
    Those overheating issues are probably caused from ignition timing being to retarded, or mixture running to lean, or oil cooler blocked.
    When you set the points you can clean the oil cooler. Check the secondary jet in the carb is not full of crap, it's probably a 102, replace it with a 107 for modern fuels seems the answer.
    The plastic to replace the bakerlite would be a phenolic resin, like bakerlite. Any good plastic/perspex supply could point you in the right direction, I'd imagine you would want something that is good up to 400'C.
    If you did chop and weld the heat transfer pipes remember to cross brace the r/h exhaust manifold otherwise the alternator belt tension will pull a stud.
    Lastly I've seen these cars banging around in 40'C heat all day without these overheating issues.
    The 2Cv is more than air cooled, its also oil petrol and spark cooled!
    Harley
