C3 aircon passenger but not drivers
Results 1 to 3 of 3
    Fellow Frogger! mattg's Avatar
    Feb 2005
    Port Macquarie NSW
    191
    Default C3 aircon passenger but not drivers
    Hi all this is the problem in my sisters c3 (2005 exclusive I think) the aircon pumps cold air out the passenger side but not the drivers.
    Can someone tell me the part number I need to fix this and is it a big job to fix it?
    Cheers Matt
    MattG
    2002 Xsara VTS
    10,128
    C3's with climate control use the same fan module as the early C5, but you do appear to have working fans. Listen for a clicking noise behind the dash as you try to change the air distribution. There's a mixer motor the size of a large cigarette packet that can strip a cog in the reduction gearing. It may be that. It's like the CX and BX intake flap motors in that they run until they stall rather than having any limit switch. The best thing is to check at service.citroen and chase a new part somewhere, maybe O/S. A used one may be OK, but you'll never know whether the cog is only 5 minutes away from failure. New parts will most likely be Valeo ex-China regardless.
    Feb 2005
    Port Macquarie NSW
    191
    Cheers David really appreciate your help on this. Any ideas of a part number? Cheers
    MattG
    2002 Xsara VTS
