DS Headlights
Results 1 to 3 of 3
Thread: DS Headlights
    Feb 2012
    Ongar / England
    811
    Default DS Headlights
    Hello, I've followed the advice on AF and bought the pre-wired headlamp loom with relays from Thailand. Now I want to change the horrible bulb holders for the 'normal' three pin affair.
    I'm convinced I read on AF about cutting the mounting rim off the old lamp and sticking it to a modern bowl but I'm damned if I can find it. Can someone put me out of my misery (before the wife does!)?
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,445
    That's the gist of it. You need the mounts from the original lamps.
    The new lamps will fit inside the old reflectors with the removal of material at the bulb mounting base, then a Sikaflex Adhesive or even an epoxy will do the trick.
    Centre the reflectors as well as possible.
    There have been more detailed instructions in the past. someone with search skills will be able to find them. Not my area of expertise.
    Hope this helps.
    8,159
    Quote Originally Posted by badabec View Post
    As Richo outlined, or you can buy Cibie reproductions here in Aus - these are plug and play
    http://www.aussiefrogs.com/forum/sho...l=1#post979520
    08 C5 X7 HDi very Noir
