CX Door trims. What is the solution?
Results 1 to 25 of 34
    Fellow Frogger! meinkiev's Avatar
    Aug 2011
    Kenya, Africa; Kiev, Ukraine, and Albury, NSW
    138
    Default CX Door trims. What is the solution?
    Can anyone suggest what is the best solution for refurbishing CX Series I door trims? We all know that they shrink and crack and pull away from the door. So what are the best ideas to remedy this? I thought it may be best to clamp them flat and take a fibreglass mould of a good one to produce a fibreglass copy and then reupholster this? If anyone has a better idea, please let me know?
    I am not very worried about keeping my car original, so I am also wondering if I can use CX Series II door trims. Will they fit?
    Also, my CX has a 2500 Diesel fitted. Can I add a turbo and intercooler from a late Series II to it, and then exchange fourth and fifth gear from the same late Series II box? Will it work?
    Thanks,
    Shane
    10,705
    Quote Originally Posted by meinkiev View Post
    Thanks,
    Shane
    Some people have made fibreglass moulds I believe (so somewhere in Australia there may be moulds for making new fibreglass Series 1 door trims. Others have fitted Series 2 trims to Series 1 cars. I have some as new trims in the garage but they aren't totally straight. On my car they are a bit cracked but it's not my highest priority job (leaks....).
    We'll be interested to hear what you do.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Aug 2011
    138
    Thanks John, I will not be doing anything just at the moment, as I am living overseas, but if I discover something ground-breaking, I will telegraph it to all.
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    616
    I have often thought what would happen if you pulled them straight and then took them to a joinery company that does vacuum wrapped kitchen doors, then get them to vacuum wrap the original trim, main problem could be getting a reasonable colour
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    I had one done many moons ago from a company that did vacuum forming repairs on dashboards. If you can still find someone that does that as Balki suggested, that would be my recommendation. I don't know about colours but surely some brown/woody shades would be available
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    10,705
    Quote Originally Posted by Greg C View Post
    Years ago, I was told the best solution was to saturate them with water and hold them straight until they dried (days to weeks I'd surmise!). I have new ones in their bags that aren't quite straight.
    Thanks for that informtion. Hadn't thought of that one. What a design....
    Renault 4CV 1951
    Renault R8 1965
    16,323
    Thanks,
    Shane
    I don't think anyone, anywhere has completely solved the series I CX door trim issue
    I think you will find the later diesels are massively strengthened. The bearings, block, crank will all be bigger. The early diesels are gear driven too, the later ones have rubber bands. The injection pump from the later car would need to be used, as it'll have the enrichment device that adds more fuel with boost.
    I'd suggest the easiest way to perform this change would be to fit the later motor and gearbox to the car. To do this would would need the different exhaust downpipes, 5spd driveshafts, 5spd selector rods, 5spd gearbox mount. It's a mechanical deisel, so I can see why the motor itself wouldn't just plug in and work
    1000+ Posts Bruce H's Avatar
    Apr 2001
    1,208
    Not the answer to the original question, but if you have solely warped trims I had success with the following when Stef suggested it / made the brackets years ago. Remove trim; spray via a pump pack the backing with water until it is just moist, then heavy weight as flat as you can (care at this point not to weight in a way that could crack the coloured section). Leave until dry, re-applying moisture and re-distributing weights repeatedly if needed until close to / flat. Then to prevent future re-warping, make up two brackets - one small L shaped one to fit at the top trailing edge of the trim and a longer more V shaped one to fit along the lower edge inside the trim. Carefully measure then screw one edge of the brackets to the door, and screw through the trim (where it is hidden when the door is closed) into the other edge of the bracket. Someone with an SM might post a photo of the trailing edge of their door trim, showing that this is the way they appear to be affixed.
    Bruce H
    Now 99 Xantia SX x2; 96 Xantia SX; 76 GS Club Estate x2; 76 GS Club; 74 GS Club; 88 VW T3 Reimo
    Before: AX Gti; BX 19TRi Estate; CX 2200 Super & Pallas; CX2400 Pallas; CX 2400ie Prestige auto; DS3 DStyle; GS Pallas; GSA Club; Xantia Image Estate; Xantia Exclusive; Xsara VTR R4; 1.4 Special Estate; Virage; R16TS
    Contact for the Australian Citroen GS GSA and Birotor Register http://australiancitroengsgsaandbiro...com/index.html
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,021
    They warp because the vinyl coating shrinks and pulls the card backing out of shape. No amount of soaking and weighting will remove the distortion because the issue of shrunken covering has not been addressed. Once the covering is removed it is easy to get the card backing to resume its proper shape. But then, how do you apply a new covering of sufficient quality to look original. This is the major problem! I tried it with papier mache and then cloth. I got rid of the distortion but could not achieve a satisfactory covering.
    It would seem that molds must be cast and that new vinyl vacc. formed to the mold then be applied to the card and foam base. I will have eternal admiration for anyone who manages to achieve this!
    Cheers Gerry
    1,475
    I do recall French Car Care in East Brisbane selling fibreglass replicas of the CX door trims but this was nearly a decade ago, mind you. I'm surprised CX Basis in Germany haven't whipped up a batch or two in any of the colour schemes available. I'm only guessing someone like Citroen Andre in Holland would have NOS ones in their warehouse.
    1972 SM
    1989 BX 16 Valve
    8,159
    Icon3
    Quote Originally Posted by donat View Post
    They do come up from time to time on ebay, usually in ones or twos so getting a full set in your colour choice would be like winning tonights lotto...
    Attached Thumbnails Attached Thumbnails CX Door trims. What is the solution?-cx-door-card.jpg
    08 C5 X7 HDi very Noir
    "Dťesse" Roland Barthes, 'Mythologies', 1957
    The Dťesse has all the characteristics of one of those objects fallen from another universe that fed the mania for novelty in the eighteenth century and a similar mania expressed by modern science fiction: the Dťesse is first and foremost the new Nautilus.
    3,021
    They can always be vinyl sprayed to the correct colour. Often the ones that come up are for Prestige.
    Cheers Gerry
    Apr 2001
    1,208
    Distortion obviously does depend upon shrinkage, but if your trim hasn't gone too far the wetting, weighting and then securing with something that holds both the vinyl and the trim in place worked for me for the couple of years I ran that particular CX. How well it lasted after that I don't know, as the following owner wrote that car off about a year later.
    Bruce H
    3,021
    The other question is, what methods can be used to preserve ones that are still in good condition??????????
    I hear that ''Armorall'' is a NoNo!!!!
    On the wetting of the base board trick. It may work on a door trim that is passable and has not yet begun to crack and peel. Most cars that are eligible for restoration have trims that are way past that stage. Therefore there needs to be a way found to re manufacture trims back to new standards, possibly using more modern UV resistant coverings.
    If this cannot be achieved the CX will become an extremely rare beast as most examples will go the way of the crusher for recycling.
    Cheers Gerry
    10,705
    They do, but you do wonder whether they would be flat?
    Renault 4CV 1951
    Renault R8 1965
    Feb 2006
    Brisbane, QLD, Australia
    515
    This has been mentioned before; the moulds for fibreglass doorcards have travelled from QLD o WA and I got a pair of fibreglass front doorcards that are possibly done with the said moulds.
    CX Register
    Fellow Frogger! rmac's Avatar
    Denmark, Western Aust.
    748
    I have the fibreglass moulds and was hoping to get my son to make me a set, then have them covered via a vacuum moulding process. He never was all that keen on fibreglass work and I've had no luck getting him to do it. If there is anyone in WA (southern) that can help then they are available. I think the moulds are only for the face - no backing mould. I can't check as they are in Perth.
    Current Cars
    Australia's 2016 C5 2.0HDi Last
    2011 C5 2.0HDi Comfort
    1973 Citroen D Super 5,
    1981 Citroen CX 2400 Pallas C-matic,
    1981 Citroen CX 2400ie Super Familiale C-matic - Raid Arctique 2014
    1991 Mazda E2200
    1924 Citroen 'la petit citron'
    10,705
    Quote Originally Posted by rmac View Post
    My recollection was that the moulds were indeed for the face. I'd forgotten they were "down South"!
    Like an earlier poster, I'm a bit surprised that Citroen Andre or CX Basis hasn't got to this one, given the Europeans' enthusiasm for good looks (not that we don't, but there are about 1,000 members of the French CX club if I recall correctly) and the size of the market.
    Renault 4CV 1951
    Renault R8 1965
    Aug 2011
    138
    Thanks rmac, I am pleasantly surprised to see that this post has flushed these moulds out. I think that some (small) fibreglass business may be persuaded to do the work of copying, especially if there may be several after them. Actually I think it's not rocket-science, it's the old problem of time. When I get back to Oz and am ready to make a start I will contact you again if I may, and perhaps we can research a good solution? Shane S.
    Aug 2011
    138
    Quote Originally Posted by kimmo View Post
    Hello Kimmo,
    What is the end result of the new trims from the fibreglass moulds? Do they look good/sit flat etc.? Shane
    Feb 2006
    515
    Default Re: CX Door trims. What is the solution?
    Couple of photos.
    The doorcard attached in the wagon wreck is off from the clips for some reason. It would sit better on the door if the clips were properly pushed in. I am taking it off and putting them in the '79 C-matic I have at some point.
    Attached Thumbnails Attached Thumbnails CX Door trims. What is the solution?-uploadfromtaptalk1352096098770.jpg   CX Door trims. What is the solution?-uploadfromtaptalk1352096123764.jpg   CX Door trims. What is the solution?-uploadfromtaptalk1352096177466.jpg
    CX Register
    Aug 2011
    138
    Thanks for the photos Kimmo. I hope this will be the answer to the door trim dilemma. Shane
    skp
    skp is offline
    206
    Hmm... I'l like to look at these..... Where abouts in Perth? I am in the midst of re-building my workshop into something really good, so Citroen restoration is on hold for a few more months.
    My CX Gti door trims are in need of replacement. I attempted the "soak and bend" treatment many years ago, to no avail.
    Fibreglass and a trimmer is surely the way to go!
    Stuart Pekin
    10,705
    Hello Stuart, and best wishes for Xmas and the New Year.
    They aren't in Perth. Speak to Ross McGuinness!
    Best wishes for the workshop - I'll have to come and have a look sometime!
    I wonder if there is a market for a few fully trimmed door cards? I have four essentially new ones although not perfectly straight of course.
    Renault 4CV 1951
    Renault R8 1965
    Aug 2011
    138
    Gerry, I have started work on my door cards, which are in pretty good condition, really. They are not cracked at all, and only mildly warped. I found some new universal plastic clips which can be made to fit the card holes, and they have a thimble shaped female socket which goes into the door. They seem to hold very well once inserted, which is what it needs to hold a warped card. But I am thinking that rather than risk damaging all the card holes by taking the old ones out and replacing with the universal ones, I will only use these where the damage is worst.
    So I am wondering if replacements for the original female plastic holders are available anywhere? These are part of the problem as they go hard over time and don't hold very well, and everyone just pushes them back in with a prayer and a wish and hopes they hold. If I can locate about 20 or 30 of these I think they will be better than replacing all the card studs?
    On the card holes where the plastic studs have pulled right out and are damaged, I have sanded the yellow plastic gooy material and card material around the stud holes in the cards, and am ready to use fibreglass matting around these, ready for the new universal studs. I feel if I can get it all set up with renewed studs and female holders, and use a hot air gun when fitting it, to stretch the vinyl covering, I hope I can get them dead flat against the doors and that they will stay that way.
    What can you tell me about the female stud holders? Are there any to be had? I have tried different ideas in place of the female holders, like 5mm plastic pipe, but they are not very satisfactory for some reason or another. Or should I try to use more universal studs and holders?
    I will detail my progress here when I start to fit them.
    Shane
