Roof position sensors
Results 1 to 13 of 13
Like Tree3Likes
  • 1 Post By GreenBlood
  • 1 Post By Plurielroof
Thread: Roof position sensors
    Oct 2012
    Italy
    4
    Default Roof position sensors
    Hello, i have a citroen c3 pluriel 1.4 hdi (year 2004)
    I am looking for the position of the sensors , specially the sensor who feel the closure of the roof. I have this problem:
    i washed my car, then waited for about 1 hour to let it dry
    then i opened the roof (about half), and cleaned the car internally
    Then, when i closed the roof, it reached the closure position, but the roof engine didn't stop!
    I heard a sound like "trrrrrrrrrrrrrrrrr" coming from the rear window, so i stopped to press the button
    Worried, i tried again to press the button, and again i heard 'trrrrrrrrrr' from the rear window....
    I suppose there is a problem in the sensor that realizes the closure of the roof...
    but the question is: where is it?
    Thanks!
    Oct 2012
    Italy
    4
    Hello,
    I did some investigations, seems that there are not such sensors....
    anyone knows how to mend the roof of my car?
    The problem is that also the rear window is locked and i can not open it....
    Thanks!
    9,670
    There are 4 microswitches in the roof assembly from memory. If any of them fails, the roof won't operate. That may also affect the tailgate glass lock.
    If you look at the free parts information that Citroen provides (see service.citroen.com) you will see you can buy a lot of individual parts for the roof. It's not unknown for the switches to fail or need to be initialised.
    You may need to take the car to a Citroen workshop and it may even be the least expensive way of repairing it.
    Oct 2012
    Italy
    4
    Ok thanks for the suggestion David!
    I am searching for technical documentation about the roof, i saw on service.citroen.com that i have to pay something to read it...(like 5 euro for 1 hour...)... but i am not sure i can find documentation about the roof there (with explanations of the functions of the components)
    I dont want to waste money...perhaps you are right...i should take the car to a citroen workshop... but before i would like to get information to be sure that its the less expensive solution... (last year i had a similar problem with rear window locked: i checked the wires exiting from the rear window, and i found that some of them were cut (at both sides of the window), so i fixed them and i did not spend any money...)
    Dec 2015
    Australia
    5
    Quote Originally Posted by vicolodo View Post
    Hello,
    Thanks!
    Hello there, jumping in on this thread-
    the Exact same thing has happened to my little C3 pluriel- I replaced the side slide in the roof at a cost of $255 each side- roof was working ok- then the same problem started-
    roof only opened one notch- closes a little bit only one position open- I can do this until I get my roof opened- but it's not correct and I can not open my boot- only from the inside-
    please please help
    8,161
    Quote Originally Posted by Plurielroof View Post
    please please help
    If you have not reinitialised after disconnecting your battery you could try this procedure. . .
    Sun roof.
    The anti-pinch function has to be re-initialised.
    Place the sun roof switch in the maximum tilt position.
    Keep the sun roof switch pressed until the sun roof ceases its movement.
    Release the sun roof switch within 5 seconds.
    Keep the sun roof switch pressed until the end of the sun roof opening sequence.
    Tailgate.
    The opening of the tailgate is deactivated on reconnection of the battery.
    Perform locking/unlocking to activate the opening of the tailgate.
    Might help to download and save this PDF
    http://service.citroen.com/dtt/CDP/d...us_t1_2005.pdf
    Hotrodelectric likes this.
    08 C5 X7 HDi very Noir
    Dec 2015
    Australia
    5
    Hi Chris,
    thanx for your time- I have attached a video that shows what the roof is doing- could not re-initialised- anti pinch function!https://youtu.be/71zu3Po_SU4
    8,161
    Hi Chris,
    hmmm, not much help so far. . .
    I'm afraid I can only be a sounding board as I have no experience with the Pluriel, but if we can keep the chat going someone with more knowledge will see this thread and offer more help.
    From what I have read it appears the roof closing is directly related to the boot lock/unlock function, so you need to attend to the roof problem and hopefully that will also fix the boot problem.
    When fitting the 'new' roof side slides did everything clip into place nicely? It seems it is important that the roof fully closes and clicks into it's final position. I'd be tempted to disconnect the battery and put it on charge overnight and go through the initialise process, this may require resetting pinch on windows as well as roof. So, windows fully lowered and raised and likewise with roof - fully open and fully close.
    If in doing this you need to reset the Sensodrive this may help. . .
    https://www.ultracars.co.uk/citroen-...set-procedure/
    Dec 2015
    Australia
    5
    Thanks Chris-
    lets hope someone catches this thread- I believe you are correct roof/boot relations-
    with the motor connected to power and hanging free from the roof- it behaves exactly the same way-
    this happenes two weeks ago- I got out of car played with boot open/closed drivers door locked/unlocked car and boot opened and roof worked- 3days later the same thing, but the next day it worked- and now after driving to shops with roof opened, closing roof- buy a carton of beer, placing beers in boot no problems- drove home (5 minutes) and couldn't get the beer out!!!- and this has not corrected itself this time?? - I feel it's the signal the motor is receiving is the issue- ??
    It is the same as this original thread- so hopefully there is a simple solution- and someone will help-
    i have carefully fitted the side slides and roof operated perfectly (thankfully) I believe I am very capabable of fixing anyone's broken roof slides if anyone out there needs help-
    Dec 2015
    Australia
    5
    Is there anybody out there???
    Its half way through summer and we have only just purchased this car, is someone able to share this link somewhere hopefully something will catch on- surely someone has had the same issue- about tri pull out the switch itself to test? I'm not sure how I'm planning on testing- but I'll work that out- next maybe roof ECU- that's just MORE money if that's not the issue?
    Help desparately needed
    10,705
    Apart from David S's advice, always good, had you thought of checking on a UK Citroen forum? I imagine there are far more RHD Pluriels over there.
    Good luck.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Citroën CX Pallas 1980
    Fellow Frogger! BallinaOB's Avatar
    Bathurst, Australia
    131
    I do not have a Pluriel, but I did a fair bit of research back a couple of years ago when I was deciding between the Plural and the C2. When it came to Pluriel roofs this person in the UK was recognised as a bit of an expect and apparently helpful to non UK residents via email.
    Citroen Pluriel
    You can email him at: [email protected]
    Good Luck.
    Anthony O'Brien
    2008 C5
    2007 C4
    2004 C5 Estate
    Previous
    2003 C5
    2004 C2 (now with youngest son)
    2006 C2 (now with eldest son)
    Dec 2015
    Australia
    5
    Thanks guys I'll email the guy and see how I go- will post any results
    GreenBlood likes this.
