New key for Picasso
Results 1 to 11 of 11
    Jun 2011
    11
    Default New key for Picasso
    Hi all
    Our 'remote' key is dead .. I have changed the battery and tried to dry the internals (in case moisture was the problem).
    So I have to assume the electricals are the problem.
    Replacement key is updards of $400.
    Does anyone know any other cheaper options to get key from o/s .. I have a local independent who can code it for me.
    18,731
    Try this mob:
    http://www.wholesalecarkeys.net/all-...r-renault.html
    I've dealt with them and they were honest and good to communicate with.
    Check they have stock before purchasing.
    16,322
    Keep an eye on ebay UK. You need a blank transponder key. NOT just an empty shell.
    http://www.ebay.co.uk/itm/NEW-CITROE...item4164f9cf74
    I've seen them for about 50quid in the past. Send them your VIN number and request they pre-cut the key for you.
    Please Note: THEY MUST BE PROGRAMMED INTO THE CAR. This is over $100aud through Citroen ( it's takes a whole 5minutes, so you can understand it costing so much ). Though someone with a lexia clone in adelaide may offer to add the key to the car for you (note: You will need all of the car keys re-added with the new one).
    Just to clarify. Getting a new key cut by a locksmith, or ordering in just a key will only allow you to unlock the car. You need a new key with a blank transponder, that someone will program into the car for you.
    18,731
    Heavens Shane at least scroll down the page before giving advice .
    This dude sells the cases, blanks and complete remotes.
    The OP already said he has someone to program the remote.
    Don't remind me!
    16,609
    I presume the OP has tried "Key in the ignition, turn it on, immediately press one remote button for about a second, turn off ignition and remove key" as a first approach to reprogramming the remote.
    The microswitches also fall off the circuitboards. New ones can be bought cheap and soldered in. It's pretty hard from what I've seen, to actually kill one stone dead.
    Jun 2011
    11
    YEs I have tried that ... should have mentioned this in my OP. I will check the microswitch tonight. Thanks!
    16,322
    This one from that website may work.
    http://www.wholesalecarkeys.net/auto...ew-models.html
    The ebay adverts make it easier as they list the exact models the key will fit (and will cut a new blade for you). Certainly the keys are far more expensive than the website you have found.
    You could move the transponder and key blade across. Addos advice should work if the key isn't dead. The lexia even tells you the exact same thing when you key in a new key:
    Victoria Point
    20
    If you try "Car key help" in the uk they will cut it from a photo or the coding if you have it. i am presently getting a spare key from them and have got others in the past.
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,892
    Word or warning - it is not uncommon for the RF receiver in the BSI to fail. So even with new remote, it still may not work. Best to make sure the car will work with another remote before ordering a new one.
    Ken W
    Jun 2011
    11
    Thanks Ken ... bear with me ...
    1. How can I make sure the car will work with another remote? I would have to get the other remote coded to my vehicle wouldn't I?
    2. If this were the problem would the entire BSI need to be replaced ... or could the RF Reveiver be replaced
    Cheers ... Tom
    Don't remind me!
    16,609
    The BSI includes the receiver from what I've understood.
    They're not obscene if bought new from overseas; that way you only need the configuration done locally.
