Xsara fan switch
Results 1 to 7 of 7
    Victoria Point
    20
    Default Xsara fan switch
    Does the fan switch fail open or shut as the fan runs constantly?
    Don't remind me!
    16,609
    Series 1 or 2?
    Victoria Point
    20
    It is series 2
    Member Chimbu's Avatar
    Jun 2004
    Tweed Valley
    94
    The attached (from Tridon cata)would suggest it fails open
    openclose.pdftesting.pdf
    http://www.ebay.co.uk/itm/CITROEN-XS...item3374aa67e6
    And, in going open circuit, sends a signal to bitron to turn fans on full.
    Hope this helps
    Keith M
    Victoria Point
    20
    Thanks for the info!!!!
    Don't remind me!
    16,609
    It is more likely that one of the controller relays has carked. Their contacts erode; I am starting to think that either you shuffle the trio of relays around between positions every year, or replace the eroded one every ten years.
    9,668
    It probably depends on the engine, but I do know a Berlingo of the same age will put the cooling fans to high and give an overheat warning when it's confronted with a bad coolant temperature sensor. Do you get an overheating warning when it's cold? The Berlingo also had a resistor pack that failed and gave only high speed fans. I'm not sure if the same concept is used in the Xsara.
