XM Window clip
Thread: XM Window clip
    Member MikeHolt's Avatar
    Jan 2006
    Elsternwick
    55
    Default XM Window clip
    Hi does anyone know where to obtain the little plastic pin/clip that fits into a hole in the front edge of the rear door window glass. it holds the glass in a track along the B pillar and stops the glass from falling aft.
    This is for an XM but may be common to other PSA cars.
    Tiny part but a PITA.
    thanks
    Mike
    Mike Holt
    C5/C6/XM/DS21
    prev CX /Xantias
    16,322
    Ask around on the XM forums. I'm sure someone will drop one in an envelope and post to you. You need someone that has a broken window regulator to send you this part. My old car may have had a couple in the hatch when I sold it They break off so should be able to be sent to you as a seperate part.
    Fellow Frogger! aquinian's Avatar
    WA
    604
    Having fixed one of these recently, I'm not sure a correctly-sized R-Clip wouldn't do the job. Anybody tried that?
    Current: 406 Coupe, 504 Sedan
    Previous: 306XSi, 205GTi, 206Gti, 505 V6, 505 Wagon, 504 Sedan, 504 Wagon, 306Gti6, 306XT, 205Si, Citroen XM, Citroen Xantia
    9,670
    It is a separate part, not part of the regualtor and has a part number. See #6 in the image in my post here:
    http://www.aussiefrogs.com/forum/sho...=1#post1109292
    I've cut off the part number in that image, but a dealer can look it up if for you.
    If you have no joy with a dealer, pm me and I'll send you one from my spare glass set.
    Member Chimbu's Avatar
    Jun 2004
    Tweed Valley
    94
    Quote Originally Posted by aquinian View Post
    I'm curious to know how to turn one of these:
    into one of these:
