*General - Electrical contacts Handy tips.
Results 1 to 1 of 1
    Melbourne, Victoria.
    1,388
    Default Handy tips.
    Hi Froggies,
    here are some handy tips that might be useful.
    When cleaning flex connector contacts like those in a CX instrument cluster, try using a typewriter rubber . It cleans the contact without damaging the plating.
    http://www.aussiefrogs.com/forum/att...ntid=688&stc=1
    Recently when I removed the cooling system header tank I found a crack in the neck where the hose connects. Although it was not leaking it was a weak spot.
    By using a hot soldering iron I melted the area of the crack. I clipped off some spare plastic material from the bolt hole support areas, and melted it onto the melted crack area to re-inforce the join.
    I used the same method to repair the washer bottle as well.
    Cheers...George.
    Attached Thumbnails Attached Thumbnails *General - Electrical contacts Handy tips.-cleaning-contacts-01-small.jpg   *General - Electrical contacts Handy tips.-plastic-welding-01.jpg   *General - Electrical contacts Handy tips.-finished-weld-01-small.jpg
